Question about Craftsman Garden
When i turn the key off the engine want shut down why?
LT 2000 riding lawn mower 20HP the engine will crank and run but when i turn the key off the engine want cut off what i need to check?
  • 756 Answers
I would check all the wiring is all good. Make sure wire are making a good connection and condition to switch.
Might be switch
https://www.youtube.com/watch?v=q8G7kxCl9hY
Posted on Mar 16, 2019
Testimonial: "the cutoff wire that go to the coil was disconnect that was the cause the engine wouldn't cut off."
  • Kenneth Simmons Mar 17, 2019
    It good when people find the problem and post it. That will help so many more people. Thank you
SOURCE:
  • 83 Answers
SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Posted on Mar 30, 2009
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
  • 19 Answers
SOURCE: lost key to craftsman lt 1000, where can I get raplacement
sears has them on a hook where the filters are located.
Posted on Jul 19, 2010
Cub cadet super LT 1550 will not start. Worked fine when we mower last time, now is dead as a doornail
If you mean that the engine will not turn over when the key is turned, then most likely the battery died over the winter.
Jul 14, 2014 | Cub Cadet Street Sign- tractor lawn riding...
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I blew my connecting rod on my Briggs 20hp and replaced
yes it is possible to put them in backwards, there are triangles on the rod and crank that have to be on the same side in order for it to be correct. If it is missfiring you also need to check you timing key on the crank. since you broke a connecting rod I would only have to assume that you sheered the timing key as well.
May 05, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Locked down motor
Unfortunately it sounds like you threw a connecting rod in other words a blown motor. The connecting rod has become disconnected from the crankshft and is jammed up between the case and the crank itself, the engine must be dissasembled and rebiult.
Nov 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Crafstman lawn rider 42" turn off after run for 2 minutes
sounds like your coil is getting hot and shutting down,, cool off and run for a while more,, coil is located next to the fly wheel,, just follow your spark plug wire and you find it,,,good luck
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT 2000 riding mower
Check the motor of craftsman LT 2000 riding mower
Aug 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsmen LT 3000 will not crank
That Briggs engine is not a good engine it has a weak governor gear that is known to come apart for no reason what so ever it may have done so and some of the parts stopped the cam gear from turning. Good luck!
Aug 24, 2009 | Garden
Engine on riding lawn mower surging
Dirty air cleaner.
May 29, 2009 | Garden
Garden Logo
41 people viewed this question
Top Craftsman Garden Experts
john h
lnbn1975
Jay Finke
Jay Finke
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
