The manual at dell covers all that, RTM, go there get the manual and read it or search the word Language.
bingo,
I guess you mean, the front if the 313, tiny LCD screen is in
wrong language, try to be clear what exactly is wrong.
PC screens or the actual printer screen.
https://www.dell.com/support/home/us/en/04/product-support/product/dell-v313/manuals
here is your official support page, see that guide.
inside is the answer.'
page.21 states, you cant read the language what to do.
amazing, no? in the manual.
found that in 2 minutes work at dell.com
easy as eating cherry pie
You can try resetting the printer.
Check your install disc it should give langue choices there , if not you could use google translate Hebrew to English.
SOURCE: i have MSI Wind U100-280US 10-inch Netbook that
You need to do the following:
If it's windows 7, Go to the windows button, click it and then click on control panel (the first menu item in the third section of the grey panel). In this part you'll see an icon with a globe and a clock.
This is the Clock, Language and Region section. Click on it and that will bring you to the detailed settings, with three icons: a clock and calendar, a clock and globe and just a globe.
Click on the clock and globe to access the region and language settings. The first drop down menu is the language setting, which you should change to English (United States)
Hope this helps.
SOURCE: Just bought a Toshiba Satellit
Open "start menu" and go to "control panel"
Click on "Clock, language and region" or "region and language" depending on your view mode
go to the "keyboards and languages tab"
click "change keyboards"
click "add" and select "hebrew"
set as you default language in the drop down menu
additionally, to swith between languages quickly, go to the "language bar tab" and select floating on desktop or docked in taskbar
hope that helps
SOURCE: Hebrew language kit problems
I have done typesetting and websites in Hebrew. It wasn't a lot of fun for me considering I don't speak the language. Word particularly has trouble with it. The best solution I found was putting the English text in a text box. You can hide the borders on the text box and change it to right alignment so that it looks like its just part of the doc and goes from left to right as it should. You can adjust how the Hebrew text wraps around the text boxes also.
I had a much easier time with Hebrew in Quark, haven't tried it in InDesign. And please don't ask me how the design department managed to steal a programmer to work on a 50+ language ad campaign. :D
SOURCE: hebrew on ka08
hi,i making ful hebrew with virtual keabord for writing SMS in hebrew for ka08,sciphone i68+,i9,i9+++ .......
you can call me
0523568540
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Printhead error
