SOURCE: T49 True Refrigerator turns off by itself, breaker not triggered
There are several things that could shut off your unit. If you are shutting the breaker off for longer than a few minutes, the compressor might be cooling off during that time, thus allowing it to turn back on. It also might be shutting off because of the pressure switches located on the refrigerant lines. Please let me know if you need anymore information.
SOURCE: Compressor runs for few sec. fans inside dont turn on at all
hi there, circulation of air inside the refrigerator run complete the cycle of refrigeration.if no fan your compressor motor trip off.there are fuse that hold the line connected to fans this was located at the backside of refrigerator,have check on this. replace the fuse.fix my rate have a nice day.
SOURCE: compressor vibrates and unit only
Okay first True uses capillary tube not an expansion valve.
You say the compressor vibrates not cooling ?
If the valves of the compressor are bad, he may mean
internal valves but usually pressures would not be good.
Give a little more detail please.
SOURCE: My true t49-f double door
Many times a refrigerator's defrost timer will go out keeping the compressor from running
