Televison & Video Logo
How do u set the remote to do the code search for a sharp model. Umber 27us60
5 Related Answers
A
Anonymous
  • Posted on Feb 01, 2008
SOURCE: code search-innovage jumbo remote /sharp television
code 118 116 101
A
Anonymous
  • Posted on Aug 27, 2008
SOURCE: Code search for Panasonic Tv on Universal remote
i need code for panasonic tv with zenith remote control
Anonymous
  • 8546 Answers
  • Posted on Apr 28, 2009
SOURCE: Need codes to set remote to sharp television
0093 or 0688
gopakumarg43
  • 76851 Answers
  • Posted on Jul 07, 2012
SOURCE: Searching for GDEX-2000 code for Sharp TV
Check this link for details.
Herb Box
Herb Box
  • 117 Answers
  • Posted on Mar 31, 2015
SOURCE: I have a Sharp 32 inch tv and an GE Universal remote needing a code to set...yr of TV not known
Here are the correct codes for your Sharp TV:
Ge Universal remote 4 digit Sharp codes: 0079, 0123, 0063, 0020, 0004, 0009, 0226, 0266, 0006, 0095, 0122
Can i use a universal remote to control a sharp model 13sb50
Yes, you can. Search the site linked here, and find out the brand name of the remote control, which have setup code/s for Sharp brand TVs, and buy that remote control. You have to set the remote controls, using the set up code. The procedure too is given.
http://remotesearch.blogsot.com/
http://electrohelponline.blogspot.com/
What is the Newstar NTR-Q7UO code for Sharp tv model 29V-FL200
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
I have a sharp TV and DVD combo. Need the remote codes for it. My remote is a onn universal model onb13av004
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
How can use any remote control on sharp model LC-32L400M-BK? What is the setup for new remote?
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
2answers
1392,1330,1326. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Need code for sharp remote control model gao35sb for sanyo tv
2479,2440,2441. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
I need to get a technomate tm7102 remote to work
You have to set it up with the set up codes to sharp. Codes to check with Sharp Brand TVs are: 1246 1224 1221
14291214 1421
1157 1307 1361
1046 1231 1047
If you wish to get more, check these sites. More setup code list, and setup procedure are given in detail.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
1helpful
I NEED A THE CODES FOR MY POLAR REMOTE TO WORK ON SHARP TV
Google the model number of the remote (and or set) with "manual" to get a possible list of codes--most remotes also have a search mode that allows you to try every code the remote has (usually about 50) one at a time to see if any will work.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
