Lands Phones Logo
H
Harriet Edwards Posted on Mar 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need access code to get to voice mail on answering machine - I have at&t dect 6.0 model SL82318
Level 3:
  • AT&T Master 6,688 Answers
  • Posted on Mar 16, 2019
Cindy  Wells
AT&T Master
Level 3:
Answers
6688
Questions
0
Helped
3532782
Points
21745
If you need the remote access code for the answering system, then the original (default) access code is given in the manual on page 50 (page 53 of the PDF) and on 55 (page 58 of the PDF). See the manual online at https://att.vtp-media.com/ecp/documents/product_Product/364/UserManual/5977/SL82118_manual_i10.pdf . Unfortunately, if the remote access code has been changed, the default code will not work. As far as I know there is no way to reset the SL82318 remote access code to the factory default remotely. See page 50 of the manual to reset the phone's access code when you are using the handset. When you use the handset and start to change the code, the current remote access code will be announced first.
Any voice mail system would be accessed using the phone number and codes from your telephone service provider. This information will not correspond to the answering system of the SL82318.
I hope this helps.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 14, 2008
SOURCE: remote access to voice mail
from a tt phone, after the message, hit * your ext # and then your pswrd.
it's just like retreiving your messages from an ext not your own.
from there you can change your access info in the admin section.
pause 5 secs and listen to the prompts from the vm syst itself.
ctess1
  • 3 Answers
  • Posted on Jun 05, 2008
SOURCE: New Voice Mail flashing light
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
Anonymous
  • Posted on Aug 12, 2008
SOURCE: GE MODEL 28811 DECT 6.0
I have this same problem. Still don't know how to fix it.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Anonymous
  • 22 Answers
  • Posted on Feb 11, 2010
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
1helpful
We have a Vtech cordless phone and have been using the answering machine. We have never set up a voice mail with our phone service, but tonight when we came home the phone was flashing with "new voic
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
VM access
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voice mail access code and press [SAVE].
How do I set up voice mail for my uniden 6.0 without answering system
If you do not have an answering system (answering machine) on the phone, you need to purchase a answering machine or contact your telephone service provider to get Voice Mail service from them. (Most charge $3-5 per month for voice mail.) The provider will tell you what number to call to set up a voice mail message and access messages.
I hope this helps.
(for most Uniden systems with the answering system, you need to turn it on and then access the system from the handset to set the out-going message and length of incoming messages allowed.)
How do I retrieve my voice mail from my uniden dect 6.0?
If you have an Uniden answering machine, select it from the list beginning here to download a copy of the manual. If the voicemail is on the voicemail system provided by your telephone company, contact them for instructions on accessing their system.
If you require further assistance, please specify the model of your Uniden DECT 6.0 system.
How Do I access voice mail on Uniden dect 6.0
Since you didn't specify the model of your Uniden DECT 6.0, I can only suggest you select it from the list beginning here to download a copy of the manual.
If the voicemail is on the voicemail system provided by your telephone company instead of on an answering machine in your home, you'll need to contact your telephone company for instructions on accessing their voicemail system.
3helpful
Voice mail blinks & won't clear
There are messages on the voicemail system provided by your telephone company. This records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
4helpful
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
I get my message to voice mail not to my answering machine at home. why
your service provider might come with voice mail system, you need to log on to your provider website and disable the voice mail or you can setup your provider voice mail to 4, 6 sound and your Digital Cordless to 2 sound before the voice mail pick up and you will see the difference.
Delete voice mail
What model Uniden DECT 6.0 phone/answering machine?
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
