SOURCE: Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem. It will also come up if your power cord is loose. You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on. It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
SOURCE: Error Code E000 on Cannon Imagerunner 1600 Copier
Get into service mode by pressing.....
additional functions key (*) key and then...
ID(#) key...
Scroll down to PRINTER then press OK
Scroll down to PRINTER RESET
then indicate YES(*)
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Any problems please get back to me
Thank You
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
SOURCE: PC745 error code - what is it. Source for manual?
that is the symbol for a paper jam. the figure 8 represents the rollers and the zig zag is the crumpled paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
SOURCE: CANNON PC745 SAYS PAPER JAM. NO PAPER JAMMED.
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Brighton2m
