SOURCE: El televisor no enciende
Can you translate in english, maybe i can help you, bcoz i cant understand some word. thank you.
SOURCE: hola, mi pc; la prendo
ok, antes que bayas al link de abajo me gustaria que abrieras el case de la computadora y le desambles la RAM memory. son dos o una tarjetita larga que esta al centro de la motherboard. no toques nada mas. solo desamblela por 30 segundos y pongala para atras. y si no ve al link este para que veas el problema de la luz roja (inglish version) ve al final de la pagina donde dice.
Computer Diagnostic LEDs (on front of computer)
http://www.dectrader.com/docs/set1/265763-003.pdf
de acuerdo a el compaq manual dice que tu CPU podria estar da?ado.
espero esto te ayude de algo.
Testimonial: "gracias, desarme la mother board y donde conecta a masa esta el estaño quemado. ya fue.... "
SOURCE: No enciende tv. La luz
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
