Question about Boating
Jest bough a elite9ti total scan chirp sonar can I put the transducer at the bottom of trolling motor. And will it work right.
    Top Expert:
  • Boating Master
  • 63,725 Answers
IT SHOULD IF YOU HAVE THE PROPER MOUNT .
Posted on Mar 16, 2019
SOURCE:
  • 8 Answers
SOURCE: motor won't run
Look at the red indicator arrow when you hit the foot pedal. If it lights up, the motor should run. If not, inspect the splices under the top cover on the shaft. They will stop the motor if corroded or burnt.
Posted on Nov 28, 2008
Editor925
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
  • 10 Answers
SOURCE: transducer is mounted on a
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Posted on Mar 25, 2009
SOURCE: transducer does not work
For 29.95 Ill tell you
Posted on May 13, 2009
SOURCE: my 570 transducer is mounted on trolling motor.
I too have the exact same problem. .6 to 6ft then stays at .6. love to figure this out.
Posted on May 08, 2010
Y cant i mount my structure scan transducer on the bottom of the boat
This is what the manual says:
The StructureScan transducer can be mounted on the transom,
jackplate, step or directly to your boat's hull.
When mounting it directly to the hull, you must purchase a high-
quality, marine grade above- or below-waterline sealant/adhesive
compound.
Jul 20, 2014 | Lowrance LSS-2 Structure Scan HD Black Box...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
My Structure Scan display is good on the left side and the right side does not fill the screen. My transducer is mounted under my boat on the step. I have a HDS8 and everything is brand new. All other...
verify cable harness integrity at base connection of transducer , replace cable or check settings easy fix would be change display unit if unit under warranty as replacing transducer is not easy and economical
Jan 17, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
My 570 transducer is mounted on trolling motor.
May 08, 2010 | Humminbird Smartcast Rf 35 Dual Display...
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Black lines on screen
Mar 23, 2009 | Eagle Boating
Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Transducer is mounted on a plastic bracket to trolling motor. when trolling motor is turned on, black vertical lines appear on my screen. lowrance x107 cdf
Aug 23, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Boating Logo
50 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
