Refrigerators Logo
s
srmb Posted on Mar 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you know if the fisher & paykel refrigerator door alarm be disabled? Model RF135B. I have to mute it every time I open the door. Manual does not indicate how to disable.
I just took delivery on the fridge. Door alarm is loud and beeps as soon as the door is opened and only stops beeping when I mute it. I could live with one beep, but it just keeps beeping. The manual does not have any information about disabling the alarm permanently.
Stan Ford
Level 3:
Genius:
  • Refrigerators Master 3,131 Answers
  • Posted on Mar 16, 2019
Stan Ford
Level 3:
Genius:
Answers
3131
Questions
Helped
903600
Points
9078
The door alarm is on a timer and should only sound if the door is left open for some time. If refrigerator is new as stated it will be under warranty so repairs will be free,
4 Related Answers
Anonymous
  • Posted on Apr 12, 2009
SOURCE: E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
raj somaiya
  • 5370 Answers
  • Posted on Jan 10, 2011
SOURCE: I HAVE AN LG REFRIGERATOR
The beeping noise is from the door alarm system. This is a safety feature and cannot be disabled. The LED will then go out automatically in 24 hours. If the doors are closed good and it's still beeping and the LED light is flashing this sounds like a defective main control board. The main board is located behind the refrigerator . -------------- But before that try reset procedure. The reset procedure is unplug the refrigerator unit from main power outlet.Wait for 24 hours.Then reconnect the power cord to power outlet and see,if still there is beeping.If still the same problem,then re-check the door and door seals.Press the door tightly to close it.May be the door is not getting closed properly.Its looking that its closed,but actually not, so press it bit hard and see if beeping stops after few minutes.In most of the case resets helps.------------- This should help.Thanks.Helpmech.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 28, 2011
SOURCE: E522BLMFD model refrigerator door alarm
The door switch has 3 terminals and wires on it. Jumper the wire that does NOT turn on the light to the wire that is on C of the door switch. If you look at the switch it will have one wire distant from the other 2.... that wire is the power wire "C". You jumper that to the wire that would be attached to the "NO" terminal. After you jumper the wire... and TAPE IT with electrical tape the door alarm should be silenced and the internal light will NOT work until you replace the switch. Label the remaining wire with masking tape... NC and Actually label all 3 wires as you remove them... C, NC and NO. Just use write that on a strip of masking tape and then put it on like a horseshoe pennant.
You can order a switch from Fisher and Paykel AU. (See number below)
Phone Contact our spare parts team on 1300 650 585
If your not in AU the door switch is very common... call any LOCAL appliance parts source and they should have one.
Thanks for choosing FixYa,
Kelly
Randy Ohler
  • 14585 Answers
  • Posted on Feb 27, 2016
SOURCE: Disable the alarm that beeps constantly when driverside door is open
Easiest way is, when you open the door. Use a screwdriver and lock the latch in the door side. Just remember to unlatch it before shutting the door. Most ever vehicle after 2000, that ding runs threw the radio. You really can't disable it, unless you know about electronics. Then you have to pull the BCM, open it up, and go on a search and destroy mission.
If you go on the Sabbath mode with your fisher ankle fridge will the fridge motor keep the fridge cold Paula
Yes... Paula,
Hello Paula,
Let's say... (for example)
Your FISHER & Paykel model number is E522BLXU...
on that model... (read about Sabbath mode)
Page 10 of those
instructions
says of manualslib.com (URL link below)
"When in this mode, the alarms are deactivated and the interior
light and back light on the display will not come on. The interior
fan will not turn off when the door is opened.
To activate press and hold MENU + DOWN + LOCK for 4
seconds"
Of course the precise buttons could vary... WHICH is why
putting in TOUR MODEL NUMBER is important for
such questions ...
Reference
Fisher Paykel E522BLXU Service Manual Dispenser Lock Key Presses measured...
Hope this helps
Carnac the Magnificent
Fisher paykel freezer it only has audible alarms and i dont know what its trying to tell me
Looking for specific answers? Provide more details.
  1. Model number of freezer will help.
  2. Does alarm beep when door is closed?
  3. Does alarm beep when door is open?
  4. How many beeps? The amount of beeps will indicate the fault code. From there, more information can be provided.
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
Fisher paykel e381t
It is probably no more expensive than a CONTROL BOARD...
POSSIBLY as cheap as a door switch...
It is sensing a DOOR ALARM... and quite reasonably
stopping ... and alarming.
You need to find the PIZZA box, poor door alignment
or FAULTY circuitry that is causing the ALARM.
ELSE
Contact the maker for support
(on your back panel... or by reading your Owners Manual).
Like (example)...
Fisher Paykel E331T Installation Instructions And User Manual Page 44
Hope this helps
Fault code F2
Hi when the door is opened for to long alarm will beep to let you know
1helpful
E522BLMFD model refrigerator door alarm won't stop beeping. Fridge eventually turns itself off because it thinks the door is still open. How can we disable or replace the microswitch which presumable...
Kelly
Bell tone
DOOR ALARM IF LEFT OPEN LONGER THAN A MINUTE. OR REGULAR DOOR ALARM EVERY TIME IT IS OPENED. THE MANUAL MAY TELL YOU MORE.
Refrigerator
the compressor might have had it
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
