SOURCE: healthstream genesis exercise bike
This depends on the model you have. There are lots of genesis bikes have manual resistance knobs on the main post, right in front of the seat. If it doesn't have a knob here, then it might be electronically operated in which case there might be a problem if it isn't adjusting with the program.
SOURCE: Wanted:Owners manual for DP Air gometer exercise bike
Scanned image of the 14 page manual that came with a DP AIR GOMETER Model 14-3800B that was purchased in 1991 is available at http://sites.google.com/site/oakrunsite/
SOURCE: I just bought a bike with Look Keo Classic pedals
The red cleats have 9 degrees of float and the grey cleats have 4.5 degees. What you describe is normal and you soon get used to it and I really like these pedals.
SOURCE: remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
SOURCE: My pedals are squeaking while pedaling on my
hi.
i cannot see any problems with wd40 on any bike and have used it myself for many years.
just wipe away any excess, and do not spray it on the pedal tops (where your shoes go) as they may get slippery.
light oil (3in1 or simillar) is also excellent on bikes instead of wd40. same advice as above.
i find wd40 works faster, especially on squeaks, but oil works for longer.
i usually use wd40 first to cure the imediate noise, and then use a few drops of the oil to keep it quiet for longer.
hope this helps
