Hi Shawn.
This is all i could find,have a look and see if it helps you out.
https://removeandreplace.com/2018/05/01/tv-has-different-color-vertical-lines-on-screen-how-to-fix
SOURCE: Fade to Blue (same as Green Arcs?)
you can turn the Screen controls down a little bit, but I suspect you will need to replace all 3 crts as most of these crt arc sets require all 3. EXPENSIVE if crts are even still available.
SOURCE: Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
SOURCE: tv would not turn on
You need to check the output voltages of the power supply module which will be the first place to start.
Read about troubleshooting here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
SOURCE: I have a white /
It does sounds lkie the symptom of bad T-CON board, you can try cooling it with electronic freeze spray for troubleshotting, more likely to have bad IC, most repair I do is due to shorted out DC filter caps such as the one in INSIGNIA/DYNES NS-LCD37HD (backlight is on but no picture due to bad T-CON board):
http://s807.photobucket.com/albums/yy352/budm/Insignia%20NS-LCD37HD-09/
I spent many hours to locate the shorted out surface mounted caps it was time consuming becuase they are in parallel, but Iwas able to find it since I do not want to spend $80 for a used board and I have nothing to lose.
http://www.shopjimmy.com/catalogsearch/result/?q=320WF01C
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
