SOURCE: Just wont switch on - I checked the fuse in the
Try to use different cable. you may want to check below link for any other Canon MP830 issue
http://pc-and-peripheral.blogspot.com/
SOURCE: Machine starts OK, cuts ok, but when I switch it
the on off switch is stuck in the on position inside the actual switch , or the ground wire that goes from the switch to ground to shut the motor down has gone bad, If you can remove the switch off to the side and safely start the motor,, remove the wire thats on the off side of the switch, if it turns off, Its the switch
SOURCE: I have no sound on my Luxor TV
Go to the Menu then go to Install & Retune
Then select First Time Install
Install again and the sound should be working.
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
