SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Testimonial: "Thanks. It worked!"
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
SOURCE: I need a routing diagram
Your best bet would be to go to your local dealer. They can help you with any questions you may have, show you diagrams with possible print outs, or supply you with any parts you may need for your machine. GOOD LUCK.
SOURCE: Is there any manual for a john deere riding lawn mower model # la115
if you look up "john derre riding mower" blog or club, I'm pretty sure you will eventuality find a bunch of lawn mower enthusiast, with alot of time and resources on their hands. Most of the time you can find rare parts, paint, manuals and lots of extras.
