SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
SOURCE: jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
SOURCE: I have a jbl eon g2 and used it at 1pm and then at
There is nan internal fuse right behind the board were you plug the power cable in. You have to split the cabinet to replace.
SOURCE: what is is the output IC no for the high driver of jbl eon
Download service manual here:
http://www.free-service-manuals.com/JBL_EON15-G2_Service_Manual_L38587/
SOURCE: I have the JBL Eon 515 Speakers.. I found a blown
did you get the problem fixed because iam having a similar problem i have a eon 515 that would not power on
