Irons Logo
f
felix Stacy Posted on Mar 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the value of the Black and Decker Steam Iron X415?
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245557
Points
21965
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Feb 18, 2008
SOURCE: Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
electrodynam
Gordon Meredith
  • 35 Answers
  • Posted on Mar 16, 2009
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Anonymous
  • 43501 Answers
  • Posted on Jul 14, 2010
SOURCE: Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Anonymous
  • 10 Answers
  • Posted on Aug 02, 2010
SOURCE: instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jul 26, 2012
SOURCE: black and decker pro finish 715 steam iron manual
go to www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.com
God bless you
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Black and decker steam iron #415 not hot enough - why
the contact switch for heat control not get good contact or dirty need to clean.
Nov 26, 2012 • Irons
2helpful
Instructions for steam clean on B&D iron
2helpful
Black & Decker Quick/Easy X415 won't stay on
Like most consumer whitegoods nowadays, the cover is 'protected' by 'tamper-proof' or security bits screws that take may forms: you can get the a set of screw driver security bits at most hardware or electronic shops.
The power cord to your iron has one or more electrical lead that has just about broken off due to fatigue failure: it is a dangerous situation because of potential arcing so I would get it fixed it as soon as possible by a 'qualified' person: that said, there are only three wires to your iron and once you get the back cover off, you can easily find out where ths break is by just pulling hard on each wires. The break would normally be fairly close so you have the option of shortening the lead (which must otherwise also be in good condition ) to where the longest break is and rewiring the leads back in exactly the same screw terminals on the iron.
Please remeber that you are dealing with a potentially dangerous main voltage appliance and extreme care is required.
Hope it helps.
Water leaks out of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Black 7 Decker Steam Express AS250 Iron
heatman101
Top Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Iron Expert? Answer questions, earn points and help others
