SOURCE: sanyo dp42841 is making a crackling noise
determine first if with sound off you have the problem---if not it is audio related and if with sound off it is still there it is inside the set....
SOURCE: My tv went completely out. Is there a reset button
Try unplugging it. That is usually the reset.
SOURCE: I need to find a replacement srceen for my SAnyo 42inch LCD CAn you help?
there should be a series of numbers such as 01. 03 etc for the chassis several panels were used but if you send a email to [email protected] they should be able to assist you in locating one.
SOURCE: Sanyo 42 lcd tv dp42841 is making a crackling noise and not sound
you must check first the audio speaker if worn out. if ok at this time you will need to check weather the amplifier ic get burnt.
