SOURCE: everything goes extremely slow.
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
SOURCE: I have a LG Verizon 3.2 phone and I was having an
If the Disable option is showing but the Enable is not then either the Play Services is enabled or your thinks it is. This information is held in the phones cache memory. Clear the cache and then start again.If you need to know how to clear the cache then post another question please.
SOURCE: Please help me I'm obsessed with candy crush and I
With Google Play store sometimes updates don't go as planned when it updates the actual app that is used to download other items to your phone. Best way to fix this is to go to [Apps] --> [Settings] --> [Apps or Application Manager] Choose [All] from the tabs to choose. Then scroll down till you find [Google Play or Play Store] From here you can click on it and then choose "Uninstall Updates" after this is completed you should be able open play store again like normal, select Yes to the terms and conditions and then be back up and running again.
