Question about Amana Dryers
Can I get a picture of the wires inside the back of an Amana NED4600YQ1 ELECTRIC Dryer? I replaced the heating element and all the fuses. I need to get the wiring correct
SOURCE:
vest6
  • 196 Answers
SOURCE: Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Posted on Jan 26, 2008
reg501
  • 413 Answers
SOURCE: Thermostat & Fuse Wiring
The heating element failure along with the symptoms you are now experiencing, may indicate blocked or restricted air flow through the exhaust. If airflow is poor, the heater will overheat and eventually fail.
Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and at this web site: http://www.linteater.com/.
Posted on Jun 26, 2008
  • 1462 Answers
SOURCE: Aquarius WD645 - dryer has stopped heating up
there is a safety device to prevent overheat. this can be a resetteble stat ie with a little button in the middle - press this button and there may be a little click as it resets. dryer will then work.
other type of safety device is a thermal fuse. this will be mounted on top of the dryer duct inside a sleeve. test for continuity and if open circuit, replace it
Posted on Sep 07, 2008
  • 1300 Answers
SOURCE: AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
Posted on May 11, 2009
  • 1214 Answers
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Posted on Dec 11, 2009
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
Heat does not come on anymore
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Feb 04, 2011 | Amana NED7200TW Electric Dryer
WANT GET HOT
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Here is a video to walk you thru the process.
Dec 16, 2010 | Amana NED5100TQ Dryer
My Amana Electric Dryer will not heat up. Model# LE8317W2. We have cleaned out the machine and the vent. I will be purching a heater element (as recommended) is that easy to replace? IS there anything else...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.Here is a video for the element replacement.Here is a video for the thermostat replacement.
Nov 26, 2010 | Amana Dryers
NOT HEATING
Hello There
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 01, 2010 | Frigidaire GLER341A Electric Dryer
My electric dryer runs but no heat.
Hello there:
There's no heat If your dryer doesn't heat, check these: Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
I will post the pictures of the heating element in a seperate post
Best regards mike
May 27, 2010 | Amana NDE2335AY Electric Dryer
No heat
Hello there:
There's no heat If your dryer doesn't heat, check these: Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block
May 13, 2010 | Amana DLE330RAW Electric Dryer
Super capacity Amana dryer is less than 3 years old. It no longer dries the clothes. There is no heat.
check your heating element in the back of the unit for breaks, if there is not heat that is your problem. the other issue can be a fuse that blew not letting power get to the heating element but the easiest and cheapest thing to look at first is the heating element
Jan 10, 2010 | Amana DLE330RAW Electric Dryer
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
Dryer taking a long time to dry
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Mar 30, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
53 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
