SOURCE: Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
SOURCE: ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
SOURCE: Printer does not print black ink - only blue.
You'll find the printhead, beneath the ink carrier, is clogged with dried ink. Go to http:www.inkjetprinterhelp.us/cx6400 and download the dismantling instructions. Use alcohol (vodka works ok) to remove the gunk and things should work ok again. If you find excessive dried ink, you may need to clean out the drain tube, but this should be obvious on a visual inspection.
SOURCE: IP90 stopped printing black
I switched to composite black, then back to all black. After composite black printed out, then all black was ok. It was a software problem, not a hardware problem. Try this first! Mike from Burlingame
SOURCE: all colors print only black does not print. New
reset your print option set automatic or color select
The ink cartridge carrier moves and stops at the loading
position unless the printer is busy.
