Question about Tablets & eReaders
I have a Telcast T20 tablet and wish to enable tablet to accept down loads when not using wifi. Can you help?
    Scholar:
  • 95 Answers
Hi https://www.hardreset.info/devices/teclast/teclast-t20/faq/tips-tricks/google-play-errors/ Hope this helps...if not...get back to me. Thanks...John,
Posted on Mar 14, 2019
SOURCE:
Authentication problem. Reset wifi and tablet. Nothing is working.
An "authentication problem" means that that the wifi does not accept the wifi password that the device is providing, or that its MAC address may be on the exception list, not allowing it to connect. Verify that the tablet is using the proper wifi password for the system you are trying to connect to, and that you are using the same wifi security (WEP/WPA/WPA2) on the tablet that the wifi is using.
Oct 04, 2015 | Dragon Touch Touch R10 10.1 Google Android...
How do I set up WIFI tablet
In the settings make sure wifi is enabled so the device can find a wireless signal. When it finds your wifi and you try to use it, it should ask for the wifi security key / code that you have set in the router.
Dec 17, 2014 | Tablets & eReaders
My Samsung tablet wll not let me load Facebook newsfeed.I can not log in to Google. It does let me access games
Make sure the wifi/3g is turned on and connected to a network with internet access. You might need to refresh your router and modem as my Galaxy Tab sometimes gets messed up if I log on to another wifi network away from home. i.e. McDonalds/Pizza Hut etc. I may be connected to my wifi, but my tablet doesn't have a correct IP address if it has one at all. The internet speed can be a factor as games don't use a much bandwidth as apps like Google and Facebook.
Jul 27, 2014 | Samsung Galaxy Tab Tablet PC
How do I get internet on my.tablet
Hi Tara, if your tablet is WiFi compatible, it should have an option in the settings to select a WiFi source and connect. Most will require the correct password.
If it is and Android tablet you can swipe down on the screen and press and hold on the WiFi button to turn it on and select which source to connect to.
If it is and iPad, you can go to settings and enable it there, then select the WiFi source and enter the password.
Hope this helps. Don't forget to comment/rate the sollution or ask further questions on this thread.
Jul 15, 2014 | Tablets & eReaders
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
How to use internet in androidtab 7
Hello , with any tablet device, including Ipads, or Androids, device, check for setting and wifi setup, or if enable, or perhaps disable? if so, enable it. check for wap and secure open wifi areas
Oct 02, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
I need instructions on how to enable cookies on my iPad?
Go to settings then down to safari then under privacy there is an option for accept cookies click on whichever option you require. Hope this helps.
Jan 13, 2012 | Apple iPad 64 GB WiFi
Cant connect to wifi
check if you enable wifi. some netbook you need to enable or turn on the wifi by pressing function key the wifi button. also check if the device driver is installed properly.
Apr 09, 2011 | eMachines eM3502074 Tablet PC
I cannot connect my Literati to WIFI
Ok! This is what I fund out personally. The WiFi connection needs to be a non-hot Wifi network. Meaning certain Wifi connections have a security lock preventing any file transfers. I tried several locations to make a connection (Coffee shops, Mc D's, Library, Work, etc.). The Best wy to connect your Literati is to find a friend who has a WiFi ruouter and ask him/her of there password temporarly.
Now you need to enable the Wifi under the settings area by hitting the menu button ans scroll down to the settings tab. select the Wifi or wireless option. Enable the Wifi and your unit should start scanning the area networks. This is where you'll find your friends link or an open unsecure network. Do not select any links that have a pad lock unless your know there password. Once you join, wait about 1 minute and the unit will prompt you to update the software. From here it all down hill..
The Hopeless Literati Guru
Dec 26, 2010 | Sharper Image Literati Reader 16375680042...
Tablets & eReaders Logo
60 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
