If your TV turns itself on and off that might most obviously be due to temperature and otherwise, to time.
Since temperature is the most obvious cause, what happens if you move things around so there's a lot more space on all sides of the TV? What happens if you add at least two inches up, down and sideways?
SOURCE: 43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: Luxor 42 inch lcd tv stanby light flashing and tv
Good day!!!!
Kindly,count the blinks of your TV because some TV have error code by means of how many blinks..
thank you
SOURCE: Luxor LUX0150001B/01 50 inch LED Smart TV
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Ihhave a 32 inch Luxor smart TV and I need to reset it back to factory settings can anyone help me?
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
