My Nikon D50 powers on but battery indicator flashes even though the battery is fully charged. Also, the memory card indicator is flashing, even though the card is not full and is fully inserted. I can't even open up the menu nor do anything with it.
Hi Have you tried resetting the camera back to factory settings? This should clear up any problems...if it doesn't it may at least let you know what the problem is? Also...do not use an SD card no bigger than 2 gigs, What is thee display showing? Make sure the date and time are correct! Get back to me if you need any more help...Thanks...John,
SOURCE: Memory card flashes full when it's not
There should be a "format card" option in the camera's system menu. do this and it may help the unfortunate equipment realize the situation:) (be sure there are no pics you want to keep as they will be permenantly removed)
SOURCE: battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
SOURCE: Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
SOURCE: no power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
