Coffee Makers & Espresso Machines Logo
Wojciech Ostromcki Posted on Mar 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Saeco Odea Giro Plus - fast blinking red exclamation mark
nikolay nikolov
Level 2:
Habit-Forming:
  • Saeco Expert 153 Answers
  • Posted on Apr 08, 2019
nikolay nikolov
Saeco Expert
Level 2:
Habit-Forming:
Answers
153
Questions
Helped
75827
Points
231
You have to prime the machine.
If that doesn't work for you, you have a problem with the flow meter.
2 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jun 24, 2009
SOURCE: saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Anonymous
  • 8 Answers
  • Posted on Feb 13, 2010
SOURCE: det røde lys slukker ikke på saeco odea
is it the green flashing light? If so it is the thermostat that needs resetting. You can return it for repair, or I have made a website explaining how to do it yourself. http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
hope it helps
Andrew
Saeco Odea Giro Plus fast blinking exlamation mark error
Are multiple problems: 1) the moving mechanism needs to be cleaned, can be blocked.
2) The heating system can have problems.
My recommendation is to service it.
1helpful
My saeco odea giro coffee machine has a red light flashing quickly. The light looks like an exclamation mark. No matter what we have done to try and correct it still doesn't stop.
First try to prime the machine.
Turn on hot water and prime about 100 ml hot water. If the red light remain you have to change the flowmeter.
1helpful
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
1helpful
2answers
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
2answers
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
3helpful
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
1helpful
Saeco odeo giro and the red squiggly light
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
