When I unplug the power supply cord from the wall receptacle I can hear a clicking sound like a power supply switching on/off. Also, the bottom metal plate of the enclosure is warm to the touch so there is power present in the system but nothing will work no clock display, CD, Tuner, Aux. etc.
SOURCE: aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
SOURCE: Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
Did you get it fixed..I am having the EXACT same problem with mine..would love to knoe how much you are spending. Should I junk it? I have had it for 5 years. Kim
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
SOURCE: HP a820n No Power-up after City Power Failure
when my computer start, theirs a red led blinking. cmputer is not starting. plz help
To activate the demonstration
In Standby mode, press and hold DEMO
STOPçon the system until "DEMO ON" is
displayed.
? The demonstration will begin.
To deactivate the demonstration
Press and hold DEMO STOP çon the system
until "DEMO OFF" is displayed.
? The system will switch to Standby mode.
Note:
- Even if you remove the AC power cord and
reconnect it to the wall socket, the demonstration
will remain off until you activate it again.
