SOURCE: I cant turn on the bluetooth on my zte sonata
Pairing is successfully completed when the other device accepts the connection or the same passkey is entered .
SOURCE: how do you use a New Generation LAX-MAX LI-S31BT
follow the instructions on how to set it up to find a phone
Have you successfully paired it with the equipment from which you wish to play audio ? If a mobile phone, then go to Bluetooth under Settings and make sure the device is visible, then pair with it. You may need to look up the actual procedural steps in the manual.
