GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE TV will not trun-on
My Ge TV will not turn on
The green power lite will turn on for 5 seconds, then turn-off, then turn on for 5 seconds, then turn-off, then turn on for five seconds. then nothing. After about 60 seconds, I press the on switch, and the pattern mentioned above repaets itself.
Any idea what need replacing and the cost?
Anonymous
Level 3:
  • GE Master 5,138 Answers
  • Posted on Aug 06, 2009
Anonymous
GE Master
Level 3:
Answers
5138
Questions
5
Helped
1004473
Points
13534
Deflection Board,Ck capacitors cp114,cp120,cp150 IF cp150 is puffed up on top it is bad also replace other 2 capacitors in same circuit they are cp150- 2200uf16v and (TWO) 220uf35v.You can order rebulit deflection board from UED -type in www.UED.com
My GE D52GW12 52 in TV only turns on after I push the power button numerous times (sometimes up to an hour). The green light on the power button comes on but kicks off after about 5-10 seconds. It is...
Thats a very easy repair which is almost always related to failed power capacitors CP150, CP120 and CP114. You can get the RCA repair kit which is the same as the GE from www.tvrepairworld.com the kit is called the ATC221 CP150, CP120 & CP114 repair kit . The kit contains the caps and the CD with instructions for the repair.
I cant ge the tv to turn on. When I press the
go to the tv and try if i dont work try to unplug your cablebox
2helpful
I have a GE cordless handset Model 27911 that I cannot get to register to the main base unit which is a GE Model 27909. I have tried followed the instructions and still the handsets says "Not register."...
trun off phone and remove battery
remove power from the base unit
and leave them unpluged for 5 mins or more
then turn both units on
and replce onto base unit . Good luck
2helpful
My ge 52' hd rear projection tv wont turn on.
replace the flyback you can get a replacement at the following link leave a email with your model number and they will respond quickly with which flyback you need they also provide free instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/
3helpful
2answers
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
Ge spacemaker II microwave. sensor error lite comes on
Sounds to me like you have a bad magnetron tube. Call GE Factory Service as there is either a 5 or 10 year parts warranty. Or schedule a service call online at www.geappliances.com
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
