SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
SOURCE: I recently had my fujitsu inverter split system
Hi: Call the person who installed the system and ask them. Any credible company will have a one year install warranty. They will most likely answer Your questions or fix the problem cheep or for free...Your system most likely has a diagnostic feature. turn onit off for 5 min. then turn back on and count all flashes they mean something to a repairman...
SOURCE: fijitsu wall mounted split system
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
SOURCE: Hi there, we have a
Indoor coil thermistor is short. Replace it. It's located in indoor coil ending with copper sealed tub. Thanks.
http://www.orionair.co.uk/fujitsu_asyg_Fault_codes.htm
Try using this link to find the code. You will need your model number.
