Ray MS made 17billion last years, is that not enough, ?
no OS on earth supports all hardware nor 38years of software.
OP no PC stated. not even clue, sure DELL but over 30 years of PC, we have not 1 clue. 1984 to today DELL, and is HUGE today.
no PC stated
nor of embroidery is hardware (usb?) and software
nor if only software is this embroidery (thing)
if software or hardware tell the makers name, and even better
the makers URL (there web address) then we (or you) can got ther and see if the maker even has w10 software support at all.
many do not. (38 years of software, and most do not run on modern PC, ) for many reasons not MS fault at all the maker
died, or does not support this product how, (it ended.)
all things have an end, our job is to manage all that stuff.
embroidery (tell what this is, elaborate this big time get x10 better answers for sure) good luck to you.
Vickie
this
http://www.premierplusembroidery.com/en/...
is this IT? I'm snatching at URL straws.
for you,
if use ask them for w10 support.
it seems to me they are saying your version is now LEGACY status.(but has and update I see)
the new +2 version also run on w10 so I looked up both for yah.
but you need to ask them, first. not us.
some of those need a LICENSE DONGLE do you have that or is it lost.? seems it does!
did you own it before w10? or bought it used?
or well you will have to sort all that out with them , all those licensing details with them we are NOT THEM.
the class , say bring dongle to class.
so did you lose that? or fail to upgrade this product?
A PC of some kind
some sewing machine of some kind
w10. (seems it is supported)
then not reading this you failed.
I googled for you and found this.
my guess is you skipped step1 (the download word !!!)
http://www.pfaff.com/SiteMedia/PFAFF/Pro...
SOURCE: lexmark x1270
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected
Important - Delete old installs
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC. (For more information Click Here)
· Download the correct Vista driver for your model. (Click Here)
· Install the driver on your PC. (Click Here)
If you are facing issues, scanning using your All in One Center, Here is an alternative.
Download lexmark driver http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:0:0:0 note (Please allow pop-ups in your browser for this website)
SOURCE: Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
SOURCE: installed new update to fix freezing problem - created new one
I had the same problem. Mine originally stopped at 23/92 files. Then after a cool night, I started it again in the morning and got 91/92 files loaded before it started to fail again. I left the disk in and after about 20 fails in a row, it finally loaded!!! Recommend you just leave it in there and it should work. good luck
SOURCE: netgear wpn 111 on windows xp - "connection failed firewalled"
Check what security encryption is being used on the wireless network. Also, if you are using MAC filterning on the wireless network then disable it and then try connecting. Moreover follow the steps below to connect to the wireless network:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
SOURCE: reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
