SOURCE: i have a hobart sr24h
It may be the wash impeller disk broke off, and cut into the bodywash pump housing. Remove the 8 screws(4 long into the posts and 4 short, into the lower cover) to remove the wash arm support. Look each side of the wash impeller on the lower housing for a slot cut, Check the wash arms for small pieces of grey plastic from the impeller disk.. Make sure the fill flow rate is 20 PSI. If your water is hard, the booster and vacuum breaker may be restricted with lime buildup. Remove and clean as required,
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
SOURCE: my sr24h hobart undercounter dishwasher is stuck
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
