SOURCE: presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
SOURCE: singer simple comes with limited feet have been unable to find
janome machine feet should fit
SOURCE: Singer FUTURA CE-250 beeping at startup.
To clean the lint is good to thread the machine with unwaxed floss. When it beeps what code does it shows at the panel?
