SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
SOURCE: mitsubishi vs-60705 grenn power button goes on
It is an error code for short protection---the most common cause for this is one or both of the pico fuses that protect the convergence IC's are bad--set will detect no voltage and instantly shut off.
I do this here for free so if this has been helpful give me a vote here. if you have questions or need help:
[email protected]
SOURCE: red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
SOURCE: Constantly blinking green light
ONLY 1 or 2 things can cause this problem----First thing to do is
remove front speaker grill--it should pull out and is secured with plastic
pegs--behind it you will find an inspection plate---Notice the one or
two pairs of wires coming from the front keyboard
of the set---remove the inspection plate and follow the wires to the
right--you can unplug both plugs(most have two and they are marked with
letters and different sizes so you cannot get them wrong)
The
idea here is to remove the front keyboard with its reset button etc
from the circuit---You will still be able to try to turn the set on
with the remote---these sets have a Receiver(large metal box to the
left as you look from the back) and if the power goes out the green
light will blink for about 70 seconds and then go out---it is the
Receiver booting up.
If disconnecting the keyboard allows the
set to turn on--you have a bad reset switch and two choices---either
operate the set only with the remote or to remove the front screen and
get at the reset switch (it is tiny) and remove and/or replace it.
If
disconnecting the keyboard does not restore the set to operation---the
receiver is bad---there are 4 or more caps and some pico fuses that can
fail in that unit---Mitsubishi no longer sells or repairs these--if it
is bad and not the caps there is a company you can send the unit to and
have it repaired--if you need to know their name let me know---you can
call them and get a quote for repairing the receiver.
SD TECH
SOURCE: My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
