Stupidly I removed the back screw thinking it would open up the battery compartment. I just got this last night and wasnt thinking. the springs came lose now im attempting to reconnect them.
SOURCE: When I open the doors normally everything shuts
you will have to look for the wiring diagram to find this but try finding the relay switch had same thing happen to my 94 camaro and that's what I dif
Check the spring to see if it has snapped anywhere within it's coil.
Remove the cable and check operation of the pedal and spring mechanism.
If all is well, then with a lever, check that the clutch release arm on the gearbox is operational. If that is also sticking, then you will have to remove the gearbox to investigate further.
If not sticking, then also remove the clutch cable outer sleeve, and replace.
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site:http://Theprocoin.com
