I have brother dcp-l2540dw. I go to the print que on my windows 10 pc and request a test page to be printer. The printer show on the lcd screen receiving data and does not print. I have tried both wireless and two usb cables. I called brother support and the told me to take it to a service center to be fixed.
SOURCE: when printing the test page
there is a problem with your cartridge and the head of your printer, because if the software is telling you that the cartridge is full therefore it could be an hardware issue, i suggest that you should try to removing and reinstalling the cartridge, if that step still dont work then bring it to a service technician and ask them to clean the head of your printer!
Hope this one works!
But i know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
[email protected]
www.romaragregado.tk
SOURCE: Brother DCP 1200 printer/copier...won't copy/print
The scan lock is the switch on the left side of the printer above the fan outlet. You flip the switch to lock it before moving the printer. Flip the switch to unlock the printer
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
SOURCE: Brother MFC-790CW Printer is not receiving any
this printer uses a 3rd party program to print over the network. try reinstalling the CD software. This will fix it. The problem is that the printer gets lost on the newtork if the router reassisgns it a new IP, other than 192.168.1.66 that it expects. Routers may do this upon resetting. You can reserve the ip address in the router settings, and make it static in the printer, but that is more work. If you can USB print to the printer, this is all that is wrong.
SOURCE: I have an HP Deskjet 5150 that will not print.
hello
i have this link for you
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02205477&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=304431
If it does not help you resolve the issue, i strongly suggest contacting HP support
God's speed :)
