A
Anonymous Posted on Mar 13, 2019
I have a Sony str db 1070 amp. The tape input volume is low from Denon drm 700.
  • Anonymous Mar 14, 2019
    Hi Robbie. The headphone socket volume on Denon is high and ok. On the Sony str dm 1070 all inputs are fine. CD, phono, tuner, surround sound. Volume level is around 53. When the Denon tape is selected I have to turn volume up to 38, which is very high. The connect leads are good quality, if any of that makes sense.
  • Robbie Goodwin Mar 14, 2019
    That does make some sense and why is this theoretically a problem and then, why is it technically a problem?
    My "obviously ignorant" Questions matter because they will show what's gone wrong…
    Accepting that when the Denon tape is selected you have to turn volume up to 38, why is that a problem?
Robbie Goodwin
Level 2:
Sergeant:
  • Expert 384 Answers
  • Posted on Mar 13, 2019
Robbie Goodwin
Expert
Level 2:
Sergeant:
Answers
384
Questions
0
Helped
87999
Points
989
Is the input volume low only from the Denon drm 700? What happens with any other device?
  • 4 more comments
    Hi Robbie. Yes it's only the input from Denon to Sony amp. All other inputs are fine. Thanks.
    Thanks and in that case, how do you know your devices are supposed to be compatible?
    Robbie, how can I find out if they are compatable?. I appreciate your help.
    Look at the specifications of each device and even if it takes many hours - which it might well even if you had a relevant, degree-level qualification - check for conflicts.
    That many of us have no idea how to read those specifications and search out the incompatibilities is not the point.
    If you want specific help, go to the manufacturer's WWW site…
    I'd like to thank everyone who has given input to this question. I'll just have to make sure the volume is not high when switching to different sources . Thanks guys.
    I'll download the relevant manuals and check the in and out specks.
5 Related Answers
Anonymous
  • 631 Answers
  • Posted on Dec 31, 2007
SOURCE: Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Anonymous
  • Posted on Mar 13, 2008
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Anonymous
  • 15 Answers
  • Posted on May 27, 2008
SOURCE: Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Anonymous
  • 3 Answers
  • Posted on Jun 02, 2008
SOURCE: Sony STR-DG510
On this model you can't HDMI is a pass though just for video, No audio, you have to run audio with composite red/white, digital coax or fiber toslink
Anonymous
  • Posted on Feb 12, 2009
SOURCE: Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
How do I set up receiver
HI YES YOURE GOING TO NEED A FEW RCA CABLES u. can use video 1 to plug youre tv in and use video 2 to plug in youre vcr ::::::::::connect youre speakers up to the red and black speaker terminals marked L & R..good luck
1helpful
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
1helpful
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
4helpful
3answers
Required free service manual of DENON DRM 740 The system hangs after WELCOME
You can free download sm from elektrotanya:
http://elektrotanya.podzone.net/?q=showresult&megnev=denon&megnev2=740&kategoria=&kat2=schematics
Sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
2helpful
Sony str d715
help, my sony str-d715 just made a blue spark. no more text on the front but lights on volume nobb and monitor tape light are working still? did it just clip the amp?
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
