Question about Watches
How to set date on a Henley TACHYMETER 350? - Watches
2 Suggested Answers
SOURCE:
SOURCE: cannot set the date on the casio tachymeter
wen u twist th big thing do it twice and press the top button to set dates
Posted on Mar 05, 2010
How to use Tachymeter in PL-12777JSBS model
Hi John
this model does not have a tachymeter only day date function on sub dials. there is a similar model 10962j which uses the same case this has the tacho function.
Dec 01, 2013 | Police Navy MF Mens Watch...
Tip
TACHYMETER/TACHOMETER - how to use it.
Many of watch brands has outer bezel ring calibrated as TACHYMETER/ TACHOMETER. In simple words this is SPEEDOMETER on your wrist, like in your car. The only difference is: it does not work automatic, but you have to have some maths basics in your brain to make work it.
The main thing is: As second is taken as measuring point (any wristwatch is moving sec by sec, min by min, hr by hr and so on), there is no actual possibility to measure speeds less than 60 km/h. This is because our time is divided to hours, minutes and seconds (1 hr=60 mins= 3600 secs), but ordinary watch on your wrist can't count smaller than a second, so, the starting point still is 60 for the majority.
The best watch tachymeters are producing/manufacturing BREITLING, as they have very long relationship with aviators all over the world. Braitling watches can count up to 1/10 of second.
OK, here is the link to learn basics of how to use tachymeter:
http://www.mydigitallife.info/2006/12/10/how-to-use-tachymeter-function-on-watch-bezel-usage-instruction-and-definition/
on Aug 06, 2010 | Watches
HOW USE TACHYMETER & WHAT TACHYME3TER MEANS
A Tachymeter helps you estimate the speed you are going.
It uses the basic formula that speed = Distance/time
Here is how to use it: (For the full article see the link below)
To use tachymeter, simply start the chronograph or stopwatch when the object measured passing the starting line. When the object reaches the next mile or kilometer marker, stop the chronograph or stopwatch. The point on the tachymeter scale that adjacent to the second hand of the watch indicating the speed (in miles per hour or kilometers per hour) of object traveling between the two points.
For example, we want to measure the average speed of a vehicle is moving. Start the chronometer or stopwatch function when the car passes the starting line, and stop the timer after the vehicle traveled exactly 1 mile or 1 kilometer. Then look at where the chronometer hand (the second hand of the watch) is pointing to, and get the reading or value of the corresponding number at the tachymeter bezel or dial. Let's say the stopwatch stop at 3 o'clock position, meaning 15 seconds had elapsed for the car to travel 1 mile or 1 kilometer. At 3 o'clock position, the tachymetre value shows that number of 240, which means the average speed of the vehicle was 240 mph or km/h.
Source(s):
http://www.mydigitallife.info/2006/12/10...
Apr 02, 2013 | DKNY NY5045 Watch for Men
Setting the date on a henley watch
Hey guys I just got Henley time zone and the big arrow for the seconds is working but the small arrow for the second isn't working.
Nov 28, 2012 | Watches
How do you use the tachymeter
Follow this link and learn:
Aug 06, 2010 | Timex 22991 Wrist Watch
Tag Carrera CV2014 Date Keeping problem.
Lets get down to the facts.
The watch may have been serviced and may have been the beginning of this problem.
BUT is it really a problem?
Changing a 1230 or 0330 still means its on the correct date in the morning.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Tag Heuer Carrera Automatic Chrongraph...
The reset tachymeter don't stop at 12 oclock
you should pull the big button fully out, then by pushing the tachymeter play/pause you can set the starting point
wish it's helpful for someone :)
Jan 25, 2010 | Casio EF503D-1A Watch for Men
Cannot set the date on the casio tachymeter
May 05, 2009 | Watches
I have a Timex T42351 tachymeter chrono alarm wristwatch which needs the time adjusting. Unfortunately, only the hour hand moves (also altering the date). I need to adjust the minutes. How do i go about...
This watch has a cool feature that allows you to change only the hour if you are changing time zones. But if you want to change the minutes as well, then pull the crown out farther. You'll find that it has four positions: Normal, pulled out one notch, pulled out two notches, and pressed in to turn on the light.
Cool.
As long as we're at it, notice the crown in the four o'clock position also has three positions. In: set alarm. One notch out activates an alarm including the hour and minutes. Two notches out only activates the minute setting, so you don't have to move the hour hand all the way around.
Also cool.
Dec 22, 2008 | Timex T42351 watch
Watches Logo
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
