Video board or Tcom or power board?
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
SOURCE: Flashing Power Light
Power supply on monitor is being pulled down. Probably a bad inverter board. Confirm this by disconnecting the power cable to the board and apply power to the monitor. The flashing amber light will now cycle.
SOURCE: red light flashing on power button BEWARE SPAM NUMBER +1-800-532-4187 BELOW
how I solve this issue of a customer of mine.
replaced power supply and one memory stick was faulty
lesson learned: check the obvious first.. .Powersupply.. if problems persists... check your ram... if you have 2 sticks of ram,, try reseating and using one at a time or swap with known good memory.
SOURCE: Red light on front flashes 4 times and picture
THE FOUR BLINKING RED LIGHTS INDICATE A FAN PROBLEM. CHECK IN THE BACK AND MAKE SURE THE FANS ARE SPINNING ON POWER UP.THE PROBABLE CAUSE IS THE LARGE LAMP FAN LOCATED ON THE LOWER LEFT WHEN LOOKING AT THE BACK OF THE TV
