SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
SOURCE: Panasonic KX-TG1033 suddenly stopped working.
I just found this on another board, and it did work
One disappointing problem with this phone that I discovered only 74 days after purchasing the system: The base units "decides" for some strange reason "to go on a strike" and stop responding. This problem is documented on Panasonic's web site and is solve-able by simply disconnecting power from the base unit and re-connecting it. This works, but somewhat lowers the confidence in the "perfectness" of this product.
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
SOURCE: It says line in use and I am unable to dial out. I
go to call setting to unbarred outgoing calls and the incoming calls.
