Sal, 3rd and 4th link is the manual shows filter an pump, other links are where you can inquire to get more info. on fuel line diagram.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." JohnDeere Z225 Z200 Series Zero Turn Mowers JohnDeere com
do you hear hydralic motor if not use test light while operating control switch up and down position, you need a helper for this procedure.if power is at switch, see if power at hydralic motor while helper work the control switch, if no power at motor hook test light to good ground if no power at hydralic motor check fuse.if power at hydralic motor and you hear no sound hydralic motor bad.if power going to control switch and not to hydralic motor either control switch bad or you have broke loose wire at switch going to motor.if all electrical system okay and when you work the up switch and hear hydralic motor running your hydralic fluid level low reason why convertible top not going up.check fluid level at the side of the motor and pump you should see screw type check plug.you should have see through side reservoir fluid level should be between min and max marks.if fluid is low check for leaks at the pump hoses and hydralic cylinders.
HIGH PITCH WHINNING NOISE IS FAULTY TRANSMISSION OIL PUMP.HAVE THE TRANSMISSION FLUID PRESSURE CHECK AT A TRANSMISSION SHOP.IF TRANSMISSION OIL PUMP TOO WEAK OR MALFUNCTION.YOUR TRANSMISSION WONT HAVE ENOUGH OIL PRESSURE FOR FORWARD GEAR , REVERSE GEAR, BAND OR SHIFT VALVES IN VALVE BODY.NOTHING WILL WORK TRANSMISSION.OIL PUMP LIKE HYDRALIC PUMP KEEPS EVERY THING WORKING..
LISTEN FOR HYDRALIC PUMP MOTOR OPERATION IN THE TRUNK AREA..IF YES YOU HEAR HYDRALIC PUMP MOTOR RUNNING MAKING A NOISE.CHECK HYDRALIC PUMP FLUID LEVEL BY REMOVING THE SCREW TYPE CHECK PLUG.PLACE RAGS UNDER THE CHECK PLUG.AND UNSCREW REMOVE THE CHECK PLUG. FLUID SHOULD BE 1/4 INCH BELOW THE CHECK PLUG HOLE.IF FLUID IS LOW ADD FLUID UNTIL FLUID LEVEL 1/4 INCH FROM THE PLUG HOLE.IF HYDRALIC FLUID WAS WAY LOW YOU NEED TO BLEED AIR OUT OF THE SYSTEM.MAKE SURE FLUID LEVEL CORRECT.START ENGINE AND TRY RAISING AND LOWER THE CONVERTIBLE TOP USING THE SWITCH.IF TOO MUCH AIR GOT IN SYSTEM.HAVE A HELPER WORK UP AND DOWN CONTROL SWITCH WHILE YOU MANUAL OPEN CLOSE CONVERTIBLE TOP BY HANDS BLEEDING AIR OUT OF SYSTEM.KEEP EYE ON HYDRALIC FLUID LEVEL WHILE BLEEDING THE SYSTEM..LOWER THE TOP AND TURN OFF ENGINE. BEFORE OPENING THE HYDRALIC PUMP FLUID CHECK PLUG BECAUSE FLUID WILL SPRAY EVERY WHERE..IF HYDRALIC PUMP CHECK OUT OKAY AND YOU DO NOT HEAR NO HYDRALIC PUMP NOISE.POWER IS GOING TO HYDRALIC PUMP.EITHER HYDRALIC PUMP MOTOR FAULTY OR FAULTY HYDRALIC PUMP RELAY BEST TO LET MERCEDES BENZ DEALERSHIP CHECK IT OUT...
IF CONVERTIBLE TOP HYDRALIC PUMP RESERVOIR LEAKS OR HYDRALIC CYLINDERS LEAK THE HYDRALIC PUMP HAS TO BE REPLACED.MAKE SURE FILL PLUG IS TIGHT NOT LOOSE CAUSING A SMALL LEAK.
