SOURCE: Rear Axle Leak
if it is the seal, you will have to remove the caliper and rotor, remove the differential cover and remove the bolt and pin inside the diff carrier housing. push in the axle and remove the axle clip and pull out the axle use a seal puller or prybar to remove seal reverse the steps to assemble
SOURCE: I cant remove a rear axle seal to a 1999 honda passport
Axle bearing and seal are made together. It is pressed on axle.
SOURCE: Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
SOURCE: I have a Honda push mower with a twin blade. I
The more slinder blade goes on second. I just looked at mine and it was second or closest to the ground when on all 4 wheels.
Good Luck
