SOURCE: After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
SOURCE: error 27
There is no other error in the 20's besides 21 for their washing machines.
Could it possibly be that?
F20/1 - The thermistor resistance has
drifted or the temperature scanning sequence is incorrect. The ambient
temperature could be below freezing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: primus washing machine error 11?
My Primus 27 keep displaying errors 43 can any one help I need to fix it
