You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Make sure the battery is good. When you press the button on the rear of the opener, just press and immediately release. Then enter your 4 digit code and press enter. If this is what you have done then your keypad must be bad.
just open the battery compartment and press the red button then open the flap on the front of the wii console and press that red button. The lights will flash on the wii mote until one stays lit then it is paired
Please follow these steps
Programming a user code There are two ways to program a user code. A 1. Press the Program key. 2. Enter the Factory Code. The green LED remains ON while you enter the 5-digit user code of your choice. After 5 digits are entered the green LED turns OFF. (To enter a new User Code, repeat these steps.) B 1. Press the red button inside the safe. The lock will beep and the green LED will come on. 2. Enter a 5-digit user code. (To enter a new User Code, repeat these steps.) Keep your new user code secure. For your records, please copy it here: ____ ____ ____ ____ ____ Programming a password 1. Press the Program key. 2. Press it a second time. 3. Enter your 5-digit User Code. The green LED remains ON. 4. Enter the 5-digit Password of your choice (any combination except 00000.) After 5 digits are entered, the green LED turns OFF. (To enter a new Password, repeat these steps. To erase the Password, press Program twice, enter your User Code and then enter 00000.)
Battery replacement Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To reestablish your Password, follow the directions above under Programming a Password. Key override If your electronic lock fails or you do not have any codes available, you may use a key override to access this unit. 1. Remove the battery cover, disconnect and remove the battery holder. 2. Insert the skeleton key (second set of keys provided) into the key hole inside the opening for the battery. 3. Turn the key to the right. 4. Turn the four bit key to the right. 5. Open the door. Signals Your electronic-lock safe communicates by means of several audio/visual signals. Red (Error) LED + three beeps indicates one of the following: 1. You have pressed Program key out of sequence 2. You have entered an invalid code or password. 3. You have let 5 seconds or more elapse between key entries. Green (Proceed) LED + single beep occurs 1. After entering each digit of Factory or User Code, or Password 2. After pressing Clear key 3. After pressing Program key Green LED only 1. Comes on after you enter a valid code/password and remains lit during the 4-second period in which the safe can be opened. 2. Comes ON in the Program User Code mode after you enter the Factory Code and remains lit until you have finished entering a 5-digit User Code. 3. Comes ON in the Program Password mode after you have entered your User Code and remains ON until you have entered a 5-digit password. Yellow LED Indicates low battery and will typically not turn ON until battery has been in use approximately two years or longer. Your electronic lock automatically performs a low battery test during each lock use. If a �low battery� condition is detected the Yellow LED will come ON and remain ON during each subsequent lock operation. (The lock will continue to function in a Low Battery state, until battery failure.) The Yellow LED will turn OFF only after three consecutive Good Battery readings or after the low batteries are replaced. (Note: If the new batteries are installed in less than 60 seconds the Yellow LED may come ON and stay ON during the first lock operation before it returns to OFF.) NOTE: It is recommended you replace the batteries after two years, or when the yellow LED remains on.
Ok, is this a Rumour phone ?:)
if so, when you charge it you have to open the side with the pull out keyboard...you have to hit the back button to get the menu going....
I have 2 LG Rumour phones, my second is the Rumour 2...and I have to open it like this after it is charged and the green lite is lit....
It may be that you need a new battery, period and charge it fully..
This has happened to a lot of my phones...sometimes only a new battery works wonders :)
Let me know if this helped :)
Techlahj
Lost contact maybe you dropped it ,that's why the wiring inside are loosen.By the way before u make troubleshoot of your appliance try to cheeck if there is a warranty.Then if there's not that's the time you make your own troubleshoot.
this just happened to us today as well. the wall pad has three buttons: one large back-lit button pad to open it and a lock button and a light button. the open button was blinking quickly and would open the door, but the car remotes did not work. I found that by pushing both the "lock" and "light" button at the same time for about 3 or 4 seconds, the back-lit "open" pad stopped blinking and went to steady green. I went back to the cars and checked the remotes there. both opened the door.
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Try tapping the drive front after pressing the button. If this dont work and the green light is flashing after pressing the eject button then the belt inside the dvd needs to be replaced.
Hi. The green light was flashing and ny transmitter in the car would no longer operate the door. On the back of the liftmaster, just below wker the small wires go in, there is a small, flat, green button. I pressed that with a stick and it solved the problem.
