Hello everyone. I have got 3 Inverters VFS-15 4 kw Now, it was locked password Really, I have forgotten the password TYP can't reset it F700=4, I can't change any parameters except parameter F739 Ex: F7- F700 enter ==>4 but not change. F701 enter ==> F701, not changge F739 enter ==>9999. can change, but I have forgotten password Sorry for the inconvenience, but I really need help Thank you for watching my question
Testimonial: "Thank you for answering my question, but I can't change any parameters except parameter F379, I used software ASD Pro to connect to PC. I connected and successfully controlled to it but could not change the parameters"
SOURCE: wireless configuration problem. It lost parameters I had imposted.
If you are using a MC909X, after entering the static IP address and WEP key etc. via the Wireless Configuration Editor, you can export the profile you created by going to the Manage Profiles area, tapping and holding the profile name until the menu appears, then select export, it will create a registry file in the Application folder of the device that will persist after a cold boot, and the settings will will not be lost.
SOURCE: Netgear WNR3500 router hardware reset?
Get a paper clip press and hold the reset of the router for 15 seconds, you'll see that near on the power cord of the router, Then reconfigure the router again.
SOURCE: Forgotten reset password
Yow dj_marcemarc,
the solution for this is formatting the phone... it means deleting the files including the contacts, gallery, msgs... etc ... everything will be deleted and restored to it's default setting... you must type in this code on your phone:
*2726*3855#
the phone will restart... and it's up to you to change the password again...
hope this will help you thanks....
*i tried it on my phone and does very well...
SOURCE: i am infoprint 6500 ,but when i change parameter
you have to call costom first
and after do your change save the costom you call
SOURCE: I was trying to reset my Denon AVR 689 to default
To reset with the unit OFF but plugged in, press and hold the speaker A and B buttons and while still holding them press the POWER button. Continue to hold the speaker buttons for another 1 to 2 second.The display should all light up and flash at 1-second intervals. If not flashing, try again.
I hope this helps
