Televison & Video Logo
Steven Garberding Posted on Mar 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need codes for a Vizio flat screen tv - Vizio Televison & Video
Chris Walker
Level 3:
Top Expert:
  • Vizio Master 1,573 Answers
  • Posted on Mar 13, 2019
Chris Walker
Vizio Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245370
Points
21965
5 Related Answers
salsaurbana
Luis Rondon
  • 56 Answers
  • Posted on Nov 19, 2008
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Anonymous
  • Posted on Jan 08, 2009
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Anonymous
  • 35 Answers
  • Posted on Jan 14, 2009
SOURCE: need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Anonymous
  • Posted on Mar 20, 2009
SOURCE: My Vizio TV screen cuts of heads.
have you tried pushing the "zoom" button?
Anonymous
  • 4 Answers
  • Posted on Jul 03, 2009
SOURCE: program my rc32 remote to my Vizio l32 tv
Try 10056. I don't remember where I found it but it works on all my Vizio TV's.
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
I LOST MY REMOTE TO MY 39INC VIZIO FLAT SCREEN T.V. MODEL D390-BO HOW DO I CHANGE CHANNELS AND ADJUST VOLUME MANUALLY?
Unfortunately, the Vizio D390-B0 only has a Power and Input button on the TV. You need a replacement remote (XRT020) or a universal remote with the code for Vizio that was programmed 6 months after the TV was released. The D390-B0 documentation suggests that the TV was released in 2014.
I hope this helps.
I have a vizio L13e tv trying to connect to a universal remote need to set ip address please help
I think you may be looking for the remote IR device codes for Vizio TV for your universal remote. I have the following codes listed for Vizio on one of my universal remotes: 1009, 1030, 1346, 1413, 1414, 1415, 1459, or 1461. Set your remote's TV mode to each code to find the one that works on your TV.
I need a code for a Vizio flat screen stereo television
Hello
Innovage jumbo remote control has no setup codes with Vizio Flat screen TV. OK.
I NEED UNIVERSAL REMOTE CODE FOR VIZIO VO37OM
i habve a vizio tv bought used need parental code for young child tv vo37om
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
4helpful
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
7helpful
4helpful
2answers
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
