So everything works up to the K99 am. checked 4 fuses on amp and are good
SOURCE: Wurlitzer 1015 OMT CD won't spin correctly
As far as I know the CD player for a machine of that age was a CDM 12. Your diagnosis is right but the same symptom can be caused by the control pcb underneath the cd player (you can see the led display to the right of the player. That's the control pcb). But generally it is the cd player itself.
However, you should also know that a similar thing happens when the laser eye is dirty from dust. But it doesn't sound like that to me. If it is dust the cd spins properly...stops....spins again....and then gets put back. If it spins as if it is having problems spinning it is usually the laser unit.
It's sensitive to static so touch any part of the metal of the jukebox that is definitely shiney metal to discharge yourself. To remove it you undo the four posi screws at each corner of the oblong unit. It's about the size of a large pack of cigarettes. Lift it up about an inch and you will see three plugs going into the sides. One on one side and two on the other. They just pull off with a bit of wiggling. (make a note where they go). While you are there take note that there are two loose metal spacers that the unit sits on, on the far two corners where the screws came out. They can easily get knocked off when you lift up the unit.
Transfer the black metal bracket piece on the top, to the other unit .....it's just two screws. And replace in the reverse order.
Make sure when you put the new unit back that you have the two metal spacers in place or it wont sit down correctly.
Have fun.
Dave F.
I've just had a look at the link you posted. That's not the right unit. Electronically it is but not the base it is attached to is not for a Wurlitzer unit. It's a rock-ola (I think). If you are in the Uk contact Sound Sense Electronics. They will sort it out for you.
Dave F.
SOURCE: Jukebox CD Player: wurlitzer 1015 cd player take about 5 minutes befo...
Faulty CD player or faulty control pcb under the laser unit. That's assuming it is not spinning at all until ages after it has put the Cd down.
SOURCE: Wurlitzer Jukebox 1015 OMT won't play CDs
email me at [email protected] for the manual and service programme
