SOURCE: Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
SOURCE: Malber 1000 Washer Dryer--Dryer doesn't heat
If this is still a problem, where is the red wire attached. Can you send a photo?
SOURCE: Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
SOURCE: CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
SOURCE: I just got a malber 1000 washer/dryer. Can it be
NO THIS UNIT USES CONDENSED DRYING AND WILL WET THE CLOTHES BEFORE IT EVEN TURNS ON THE HEATER. BASICALLY YOUR COMBO USES STEAM CIRCULATION THRU YOUR CLOTHES. AS THE SMALL WATER PARTICLES IN THE STEAM MOVE THRU YOUR CLOTHES IT COMBINES WITH SMALL WATER PARTICALS IN THE CLOTHES(THINK OF 2 WATER DROPS COMBINING ON YOUR WINDSHEILD AND HOW THEY ABSORB TOGETHER) WHICH RISE TO THE TOP OF THE TUB AND COLLECT INTO WATER AGAIN. THEY THEN ROLL DOWN THE SIDES OF THE TUB AND COLLECT AGAIN AT THE BOTTOM TO BE PUMPED OUT. BEFORE THIS PROCESS EVEN STARTS THE UNIT WILL ACTUALLY ADD WATER TO GENERATE THE STEAM. MOST PEOPLE FIND THAT IF THEY WANT TO JUST FRESHEN UP SOMETHING, IT WILL END UP DRENCHING WET IN THE FIRST FEW MINUTES.
