Question about Frigidaire Ovens
Frigidaire oven FEB30S6DCA. The down button to lower the temperature doesn't work. Oven temperature is automatically set to 350, and I have no way to go under that temperature. Can it be fixed?
    Top Expert:
  • Frigidaire Master
  • 63,052 Answers
SURE IF YOU HAVE ENOUGH MONEY TO PAY A REPAIR SERVICE
Posted on Mar 14, 2019
SOURCE:
SOURCE: Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our.  Easy fix and part is about 35 to 40 dollars.
Posted on Dec 16, 2007
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
aborcass
  • 2651 Answers
SOURCE: Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Posted on Nov 27, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
SOURCE: Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Posted on Jan 10, 2010
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Gas oven doesn't get hot enough
Good Morning Friend,
I understand that your Frigidaire oven will not heat to temperature if you set it to 350 degrees. I see that you have to set it to 450 degrees for it to heat up, and then turn it back down to the desired temperature. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock and try setting the temperature to 350 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
How to turn on electric frigidaire oven; fgf337gud?
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Why can't i set the temperature on my frigidaire oven model # FFGF3053LSC? Burners work. I have unplugged it and plugged it back in. I have checked the circuit breakers. It still does not work. ...
Good Afternoon Annette,
I see that you are having trouble setting the temperature on your Frigidaire oven, model# FFGF3053LSC, even after resetting it by unplugging it. First I would make sure that you are able to set the clock as well. Try setting the clock by pressing the clock button and then pressing and holding down the up or down arrows to change the time. If you are able to do this and not set your oven, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why you are unable to set the temperature for your oven. Hope this helps.
-Best Regards-
WP
Apr 25, 2014 | Frigidaire Ovens
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
RBS305PDB6
The 350 as you stated is a default set point that you see before you start the cycle. What you should see afterwards (start bake) is the current temperature - which would normally be lower than the set or desired temperature - it will eventually get there
Regards
Jul 19, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
52 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Sal De
Marvin
Marvin
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
