I have no direct idea but you could try a few things........
I assume you get these via an aerial, the first I know is obvious but are they on air in your area? then I would try feeding the TV via another aerial to see if this brings it back ( aerials and cables can decay and cause many curious effects to notch out signals) so if a second aerial works replace your original system.
The TV may have a skip option to jump/ignore some channels check on this, failing this factory reset or tune again and store. Also with previous point if TV small move to another location (next door or friends house).
Sorry best I can think of other than a service engineer ......
SOURCE: Not able to connect to TV channels being SABC
you need to explain,what is sabc,dstv,what is the tv,we r not mind readers
