Galaxy S7 phone, HP deskjet 2600 series printer. HP support website has proven to be ABSOLUTELY USELESS. All they offer are a couple pre-generated responses which direct me to seek help elsewhere!
SOURCE: Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
SOURCE: HP deskjet F2100 series printer
i bought hp deskjet f2100 series printer and automatically driver was curupted from my system and now when i am trying to reinstal it again it shows error no hp printer found ...so please give me solution
SOURCE: Have Windows 7 on my laptop. Have a HP Deskjet
simply download the new drivers from HP and install them , that will fix your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: New Generac Generator--Battery Goes Dead
Yes,if its working correctly,you should be getting a reading about 2.5 to 3 volts above the battery voltage rating while its in standby mode.
SOURCE: i need samsung galaxy s
Hello thanks for using fixya
General
Packet Radio Service (GPRS) is a packet-based wireless service used for
sending and receiving data through the internet protocol. With GPRS,
the transmitted data is divided into various 'packets' before it is
received by the user.
To use GPRS, users require:
Setting up GPRS for your phones:
Usually activating GPRS on your phones are done by the service
providers, and different service providers have different
configurations. Additionally, the settings for GPRS vary based on the
different phones and phone models. As activation is required before
setting up you should know that activation process vary from one
provider to other. It could be as simple as sending an SMS to a
particular number or calling customer care of that particular service
provider. Once the activation is taken care of, the setting of the GPRS
is done based on the model of the phone.
It is important to note here that the setting for GPRS is different
for different phones companies and may be different even for the
different models produced by these companies.Therefore, it is recommended that you rely on the information given
directly from the service provider. Again activation process may be
different for postpaid and prepaid customers. So just call and demand GPRS settings for samsung galaxy s19000 amoled by the service provider, They will send it free.
I hope this solution will helpful 4 u
Please
don't forget to click on Four thumbs which are given below & then
write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
