SOURCE: Fridge freezer controls
TURN THE FRIG. TEMP CONTROL TO COLDER THIS WILL OPEN THE FREEZER FLAP MORE AND LET MORE AIR IN FRIG.ALSO THE TEMP CONTROL COULD BE BAD,TURN ALL THE WAY OFF AN TURN ON SLOW AND LISTEN FOR A CLICK IF NO CLICK THE CONTROL IS BAD,THANKS-MIKE
SOURCE: My LG B197WV has a
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
SOURCE: Temperature Control not working on 1999 Ford Explorer
Sounds like your temperature actuator is not moving or your temp door is broken. On max a-c ,coolant is shut off to your heater core allowing only cold air in.
SOURCE: Temperature warning light coming on,on a 1992 Volkswagen Golf GTI
The thermostat will show what the guage shows. the seal on the coolent bottle can be checked for tightness. so it could be a faulty sensor?
SOURCE: The freezer is not cold enough but i don't see a
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
