Question about Casio Watches
What is the small letter p showing in display of casio gw1400da
2 Suggested Answers
SOURCE:
vladp995
  • 81 Answers
SOURCE: Unwanted letters DEG show on Casio FX-100A display
No!! deg mean degree the system of answers you get, you can change it to rad=>radians but you never get rid of them. Sorry :(
Posted on Jul 06, 2009
My Casio analogue display is showing 5 minutes slow whilst the digital display shows the correct time
If old model ana-digi watch you have to manually synchronize analog time with digital display.
Nov 15, 2015 | Casio Watches
I want to change time zones on my casio edifice. I can't work it out.
Press the button on the top left-hand side of the watch until the display shows the current hour and the letter "P," "M," "C," or "E" which indicates the current time zone. (Pacific, Mountain, Central or Eastern.) If the time zone is not correct, press the button on the top left-hand side of the watch until the correct time zone is displayed.
Feb 28, 2011 | Casio Watches
I can barely read the display, cam i change the face color its dark with dark letters and numbers
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Aug 13, 2010 | Casio G 9000MC 3DR G-Shock Mudman watch
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
GWM850 7 all blank - not working
If you haven't got instructions on how to do this, you can get
watches;
Accept terms
May 15, 2010 | Casio GShock Solar Atomic White #GWM8507CR...
How do I adjust the digital as well as the analog time on my casio gshock model # GW1400-DA
To obtain an instruction manual insert "world.casio.com/wat/download/en/manual/" into your search engine and you should get the manuals page of the Casio world web site.
Insert the number requested in the box and you will be able to read the manual.
Jan 12, 2010 | Casio GW1400DA-4AV Wrist Watch
Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Jan 10, 2010 | Casio Watches
Analogue display does not sync with digital
Go to the Casio web site. Download the manual for the watch. Go to the section called "To Adjust the Analog Time." The answer is there, step by step.
Sep 22, 2008 | Casio G-Shock GW500A-1V Wrist Watch
I have changed the battery in my Casio 1604 a200 watch but now the screen isn't displaying correctly. Is there anyway of resetting the watch?
I realise this post is 4 years old now but what the hell! If you open the back of the watch you will notice in the top left corner a small hole with the letters AC above it. Push something metallic into the hole to make contact with the metal backing. This will reset the watch and the display should then be fine.
Shane.
Apr 15, 2008 | Casio Watches
Problem with the time setting
The only info which continually flashes is a dart and the letters chg
Feb 02, 2007 | Casio G-Shock G510D-1AV Wrist Watch
Watches Logo
19 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
